Now that's what I call a high flow cat!! :cheers:;)
Nice job Brendan. Mate, I'm not too far away, if you need a hand sometime give me a shout. What guys like you an me need though is people with tiny little hands to get in all the tight spaces...
Richard
  • Replies 49
Richard - I have no clue what you are talking about.
Well - nearly got the HKS 2835R on now - Pics to come.
I got one nut on the turbo flange to go - that's it - It's a tricky little bugger - You are right Richard - I need someone with small fingers and hands to get it started.
So should be back on the Rd soon - need a reducer/silicon 90deg bend if anyone has one lying around.
Then small adjustment to the tune to compensate for the slightly smaller turbo - and Bob's your Uncle.
Cheers,
hehe.
Just wait 'till 3pm, then head down to your local High School as the year 7 kids come out just offer one of them a free ride in your line if they'll squeeze their little hand in there and start the nut for ya. Wait a minute, scratch that, possible persecution as suspected peadophile might make this one for plan B. Instead just keep fu:)
Good job. Now I wanna know when you can take me for a spin!
hey!! I am missing something? I just saw the words HKS2835R in your post? what happend with the 3040? I though it was the shiznit? just a check/fix needed then back on it goes?
Will still be a weapon with the 2835, I imagine it will come on boost pretty hard and early compared to the 3040.
R
Nah - a challenge :D
Richard - 2835 is interim - whilst I decide on 3040 options. Also to see the diff between the 2835 and the 3040 with the same setup.
Options for 3040:
a) GCG Rebuild $950
B) New Garrett CHRA from the US $ approx $1200 delivered
c) GCG Rebuild and new compressor - prolly about $1300
d) looking at other options too - anyone got any other thoughts ?
With the new Comp wheel - should be a beast. But where to use all that goodness ?? ha ha ha :)
B-man, I don't have a 90 deg elbow handy, but if you can wait while I nip down the shops I can "fabricate" one for you using cardboard and masking tape. Trust me bro, my bother uses these hoses on his 8 second RX3.
Fully.
Richard
Well boys - it lives.
As it turned out, I had a 90 deg reducer bend left over from one of the other turbos I had on my car at some stage :)
So it's running - I took it for a burn tonight - boost comes on heaps earlier - I can tell cause the BOV makes heaps more noise, and earlier, compared to when the 3040 was on.
My dash lights are all busted (fuse I think and havent been f'ed fixing it), so I couldn't see tacho and boost guage - tomorrow , I'll get a much better idea of what is happening.
Quick tune to make sure everything is in order and lets see what happens.
Shit I have learned a lot about turbos doing all of this.
You can theorise all you want - but see shit for yourself really drives home the differences in compressor size, AR, turbine size and what effects these have on the charactaristcs of your turbo/engine combination.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
