After 3 engine failures I am finally back on the street with a Skyline - at last.
The R33 GTR is going again, with it's 3rd (& hopefully final engine build)
After the last fiasco just before the last 4,6&rotor nats in Feb (when we made 480rwkw then cracked the block on the friday before the meeting) the street GTR is up & running again.
This time the R33 has a brand new N1 block, new aries forged pistions, smaller 272 HKS cams (the 288 step pro cams from the race GTR are going into a 3 litre that Mark from Rhemac Motors is building for his GTR) & a conservative run in tune
at 1 bar. Tim has tuned the motec at Tilbrooks (who did an excellent job of getting the car ready) & the GTR currently has 375 rwkw (500hp).
The only other change is the gearbox, which is now an OS Giken Sequential 6 speed. This box has bigger dogs then the Holinger & should take the pounding of street use better than the finely tuned Holinger box(which is staying in the race GTR)
I have only started running in the GTR over the last week & hopefully will have it sorted ready for the skyline cruise later this month.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/
Hey my Dad used to be the engine builder at Rhemac Motors :D.. he retired about 12 months ago after 20+ years there :D.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1017992
good work John, whats the power curve like? also didnt you have a ppg box in their for a little before, did you get a chance to use it much and why the OS 6 speed?
Joel, yeah Tim Possingham now works with tillbooks and has done for a while now, catch up boy
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1018384
The OS engine is still in the race GTR (which will hopefully be ready before the 4,6&rotor Nats/ & Drag Combat). Yes I did try a PPG box for a little while.
I am testing out the OS 6 speed because I like the sequential changes (& the extra gear)
It sometimes does'nt grab the next gear if not shifted firmly enough - will have to keep practicing.
The power curve is OK for now - is still pretty conservative(I want to get some use out of this engine - not blow it sky high like the previous setup.)
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1019971
I thought I'd seen the beast tucked away at work a few times lately John. It inspired me to bring mine out for the daily commute a bit more mate! Congrats on being back on the road. Feels good doesn't it?
Tim is a damn fine tuner and I have no doubt that this motor will hold together over the long term. A little less power is much better than another failure! And more money/time.
I'm toying with the idea of going for a bigger turbo on my thing... not sure exactly what yet but 'nicely' into the 300+rwkw region would be the aim. See what happens I guess.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1022270
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
