  INASNT said:
y the hell would i need to do homework on turbos that blow after a few thousand km's?? My turbo works fine. I think you need to do research my friend as to why ur stuff keeps blowing up :)
Maybe its similar to my turbo recently declared totaly screwed after 2/3000 K's :Oops:
Had the turbo high flowed and changed from roller bearing to normal oil bearing.
TROUBLE IS the oil supply line was not modified to supply a lot more oil to suit the oil bearings!
The std oil supply line has a restriction in the banjo fitting on the block to suit the reduced amount of oil required for roller bearing. :P
So I have now drilled out the banjo restricter so it will get full flow when it goes back on soon after being refitted with the largest flowing T4 comp wheel.
But I have retained the std small turbine housing with the backcut wheel for good low down response - hope it wont choke, but have a full 3" custom dump to 3" cat and 3" S/S exhaust. :)
LOL INASNT listen here if you actually used your 300rwkw on the track strip or even the street you would realise that stuff breaks maybe not turbos but other items.:P
or you are driving it hard and its jsut not making more than 200 rwkw to break anything :)
/me grabs his keyboard and raises it in the air :upurs:
I am infact heading to falls creek for work on tueday morning, so if you want you can meet me in bright and you can race me in my company car (BA XT) from bright to mt beauty coz there some sweet mountain trails through there :P
Or come race at sandown next month :)
  INASNT said:
No shit other things break, but we are talking about turbos and bearing faliure here and you dont need to drive it at the strip or track for that to happen!!
And even if my car was making 100rwkw its still more than urs does boxing.gif
Peace Out :D
ahaha lolz, he was bagging me at mas for not getting a line, and he is NA!!!! ahahahaha the irony is sweet
  INASNT said:
OBEHVE is running a RB30 hybrid just like TRY09S i think.
Scotsman/marcus see you at sandown next month, cant wait should be lots of fun :D
He's runnin the rb25 bottom end and head, going by the article in zoom, a while ago.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
