I didn't make any assumptions.
*It looked like one car on a dyno in the video footage [heavily compressed and not great, clear quality].
*I saw 1 screen.
*Where is the assumption?
I am keeping the text nice and simple for everyone to follow...
hahaha, I believe the assumption is quite clear - You assumed the 334kw dyno screen was indicating the result achieved by the yellow supra. Case closed. :)
Btw, I dont have an issue with you champ, I simply wanted you to note you were wrong, plain and simple...
If you are looking for something to pick at me with, you are going to have to try harder for a real excuse to have a go at me -oh, and good luck.
I think you do a good enough job at making a fool of yourself as it is, no assistance from me required here... you fearsome keyboard samurai :(
  • Replies 189
You are wrong there is no assumption, the video footage shows only 1 screen. I don't think you know what an assumption is.
As for "case closed": you are not the judge and you never will be, do not bother even trying to judge me, get over yourself.
Also
Refer to "case closed" comments [once again you are not the judge].
Anyone who reads any of my posts on this page can clearly workout that I was either mislead or WRONG - as you put it!
you fearsome keyboard samurai :D
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
