Bit of a long shot to post here but here goes.
I've got a 99 lancer gl sitting in my back yard, smashed at the front with slight damage to the firewall. Basically this cant be fixed cheaply and has been abandoned by my insurance company (longer story) so i wanna do something with it!
plans: since the front right arm is bent
tube frame front end with an CA18 or SR20 turbo in it, with conversion to RWD!!
just wondering if anyone knows if the chassis of the FWD lancer i the same as an EVO lancer????
just to make things easier and not have to build a new tunnel for it, i have notice that the fuel tank is under the rear seat so this will have to be removed, just hoping that with that removed i can run a tailshaft through! just running a fuel cell in the boot.
if any one has seen lancers with similar mods or RWD conversion if they could post links/pics that would be great. this is a weekend job just for a fun track/drift car!
any and all suggestions welcome!
cheers :D
https://www.sau.com.au/forums/topic/51419-lancer-modding-about-to-begin/
  • Replies 53
hehehe yeah i know, but its just sitting there and cant do anything else with it!
i had a look a while back, it has a tunnel but not sure if it is big enough to run a tail shaft down! not a hard thing to create a bigger tunnel, have done them before, but hoping that i dont have to do it!
fresh, if you find a mag with it coudl you check for me!
I was just showing what i've seen in relation to modded lancers, I wansent telling you to do the same :D
I'd go with your idea!!!
FWD you brake to many drive shafts & no traction...
Rwd is more fun, I'd Go SR20DET and it will be a serious weapon.:)
I'm curious to see the end result
:D
i'd say it would be too much work to make it RWD.
If you want to do a project, i'd sell the car as is for a few grand if possible, buy an R31 and do an rb20det/rb25det/rb26dett conversion. At least then it will bolt straight in, it will already be RWD and you'll be driving a nissan :D
who are you and what do you want?
every post i've seen of yours is utter stupidity
warned for trolling - 5 points
Excuxe me but who are you and what do you want?
If you dont like what i write dont read it! Everyone is entitled to there own opinion, I just dont like lancers!
I am very offended by you warning me! :):):rant::rant::rant:
well i understand your feelings and i am hearing that you are offended
i hope we can reach a mutual agreement and understanding of terms in this matter
lets try to work through this and be better people for it
:bananaman :bananaman :bananaman :bananaman :bananaman :bananaman :bananaman
I am very offended by you warning me!  :)  :)  :rant:  :rant:  :rant:
Entitled to opinions maybe, but have you heard of the phrase "If you don't have anything nice to say, don't say it"? There was nothing constructive about what you said. I know quite a number of people with EVOs that would probably make you cry if you went for a ride in driven hard.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
