thanks for the inputs linda!!
anyway... back on topic!
i dont really want this car to be on the road, and dont really wanna outlay any money for the shell, plus its a good start to making different cars seeing we'll be doing all the work ourselves!
pentae, true it will be heaps of work, but i'll still be selling the engine and g/box, and all the interior etc.. so basically the only thing left would be what would go off to the scrap heap.. can get the materials for the tunnel and tube frame for free....... so why not do this definately something different :D
Flipmo, yeah i realise the EW setup for current engine but the firewall is actually bent already.. will be cutting it out and welding in a new tunnel so i'll be able to mount the engine back behind the front strut to get a better weight distribution...
  • Replies 53
Oops, i forgot you were putting in teh tube front end :D
i think the evo n normal lancers have a different track (is it called track?)...distance between wheels...
get a fwd sr20 and rear mount the engine so it makes it rwd :D
hmm true i didn't think of that..
but rear mount would have it's own problems, couldn't imagine how you'd hook up the linkages from the gear selector to the box! could look into something like a 3sgte or something
hey john, yeah like i said, this wont cost me much at all.. just have to get an engine!
i actually have got 2 CA18DET blocks at a mates so i could rebuild those and use that .. outlay cash on a g/box and i can get diffs for like almost nothing
and all the work i can do myself which costs nothing! and i am basically stripping the whole thing anyway .. only things staying is shell and steering rack and front suspension wouldn't get much for those things anyway :D
I take it you are in for the long haul with this project lol.
First up, you wont be able to race it in any category, even sport sedans, so it will be a club car right? hillclimbs, supersprints etc?
The trick will be getting the rear suspension in, I would assume that everything back there is totally different as far as hubs, diffs, struts, mounting points etc etc etc.
And just go one of those ca18s, you can get sufficient power out of them but they are heaps cheaper than SR20s :D
dude you cant make it NA. Make sure its turboed :cheers:
and i was reading Autosalon magazine, had an article about a 2dr lancer that has evo drivetrain fitted, and they had to cut the rear floorpan out and weld in evo stuff.
dude you cant make it NA. Make sure its turboed :)
hey, thats what i was not hoping for :) oh well doesn't really matter about cutting it out and welding the new stuff in as it doesn't have to get engineered or anything!
is that the new Autosalon magazine? might get it and read up on what they did!
And just go one of those ca18s, you can get sufficient power out of them but they are heaps cheaper than SR20s :)
yeah i realised that i wouldn't be able to race it in a CAMS series, but forgot about supersprints etc ... this is sounding like a better idea by the day :)
yeah whole rear subframe will have to change, just has the independant rear bolted direct to the chasis, so the end will be cut out and a new 7.5" diff welded in!
yeah should rebuild the CA's cause we got all the parts! plus the car is under1000Kg's so it should go well just as a stocker!
or go to some Msian car forums and ask around...
lots of FWD Protons and Mitsus converted to 4WD :)
please explain where!! Msian?
dont want 4wd too much money involved with engine transmission and 2 diffs .
Bit of a long shot to post here but here goes.
I've got a 99 lancer gl sitting in my back yard, smashed at the front with slight damage to the firewall.  Basically this cant be fixed cheaply and has been abandoned by my insurance company (longer story) so i wanna do something with it!
plans: since the front right arm is bent
tube frame front end with an CA18 or SR20 turbo in it, with conversion to RWD!!
just wondering if anyone knows if the chassis of the FWD lancer i the same as an EVO lancer????
just to make things easier and not have to build a new tunnel for it, i have notice that the fuel tank is under the rear seat so this will have to be removed, just hoping that with that removed i can run a tailshaft through!  just running a fuel cell in the boot.
if any one has seen lancers with similar mods or RWD conversion if they could post links/pics that would be great.  this is a weekend job just for a fun track/drift car!
any and all suggestions welcome!
cheers :)
Sell stupid lancer crap poo and do skyline faster. :)
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
