Yep, it's a problem.
Best bet is to fit a turbo that is matched to your engine or to mask the problem get a boost controller that can reference boost against revs so you aren't trying to stuff too much air into the engine at low revs.
Sorry to still seem slow, but how do you mean cant swallow you mean that the turbo is so large that the boost goes so high the turbo stalls untill it gets enough exhaust gas to get going again?, Would have to be one hell of a efficiant turbo to do that?,
Nathan
It's more airflow levels rather than extreme presure ratio i.e. the turbo's producing 100 squares of air at 5psi and the engine can only "swallow" 30 squares, so air comes back out the intake system via the turbo. The main reason for it is the exhaust housing is too small - if you go up a size (or two) in exhaust size it should sort the problem out by bringing on the turbo later, when the engine can make use of the airflow.
Actually the opposite, it takes a badly matched turbo to do that - at least one that is badly matched to the engine it is bolted on to. This is the reason you can just leave the same exhaust wheel on a turbo and bolt on bigger and bigger compressors to move more and more air into the engine. A very efficient turbo strictly speaking would be PERFECTLY matched to the engine, shoving just the right amount of air for the engine into it over a wide rpm range.
The needle might turn into a blur, and you will hear the dreadful noise, the engine might not not be terribly happy either abut the rapid pressure fluctuations. The effects can vary quite a lot from hardly noticeable to turbo end engine shattering violence. It all depends on how bad the surge is.
All turbos can surge if the compressor flow drops below a certain value. As lithium says bigger and bigger compressors surge at higher airflows. There is a myth that huge compressors will force more air through the engine. It simply is not true.
If the engine has 10psi boost with a small compressor, and you fit a humongous compressor wheel that also makes 10psi boost. The engine just sees 10psi and flows EXACTLY the same amount of air. It might be more efficient at the top end, but if you have a decent intercooler, that does not matter either.
Suppose the air going into the intercooler is 120C and 50C coming out. You fit the monster compressor wheel and the air going into the intercooler drops to 90C, and the air coming out of the intercooler to 47C. Hardly worthwhile doing. If it also now surges, you have wasted your money on that "hi Flow"compressor wheel.
so are you saying that hitting my 0.80 bar at 2800 rpm with a standard turbo is not good, i mean, it hits that, the the car seems to be pulling pretty hard, still going faily slow, but uphill, in 3rd, doing 40kmh at 0.80 bar seems the turbo is spooling up v fast for under load ...
just wondering ..
I was getting some compressor surge in my car when I was running the boost too high- the boost needle would hit the right amount of boost straight away but it would take the car a second or two for you to feel the take off- you're better off lowering it down a little until it stops doing it or you could do some damage eventually- my turbo has got a small leak because of it........@##$$#%$#!!! hehe
My car runs, from 2800rpm 5psi boost then at 3800rpm she reaches full boost (10psi) the needle is steady, she pulls well but not really hard untill 4300rpm, i just assume that the engine is just more efficient at those revs, as on the standard turbo it didnt get going till the same revs but came on boost earlier????.
Nathan
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
