ATTENTION: NOOB Question!
Im gettin a fmic next weekend and was just wondering if its worth goin on a dyno for a tune. Only mods at the moment are POD filter exhaust and runnin 10psi, but once the cooler goes on im gonna run 12psi. Just thought i might wack it on a dyno just to get it tuned properly so it runs really nicely. Is this possible with the stock ECU?
Thanks in advance
https://www.sau.com.au/forums/topic/51449-dynotune-stock-ecu/
Not really no,
But you can reset the ecu after installing the front mount and it will self learn everything over again.
Do this buy disconecting the battery and pumping the brake pedel a couple of times and reconnecting again. After starting car let it idle for a couple min's then turn the a/c on and let it idle for another few min, then take it for a drive.
hope that helps
Yeah i was told about this, but i dont want to disconnect the battery because it will reset the alarm as well which is not somehting i want to do as its a pretty razy alarm and re programming it or whatever u have to do would not be a 5 second job to say the least
Only to check your A/F ratios to get them running around 12.5 under full boost, The only real way you can change this is to change the ammount of boost your running.
eg: You carnt alter the fuel maps, so the fuel is set as standard so you have to get the right boost pressure to make sure you arent leaning it out, this could mean you have to runs less boost to get the a/f ratios right, untill you can afford a bigger fuel pump.
If you wanna get something like a SAFC to start with.
Should be able to get one reasonably cheap 2nd hand. They can be dyno tuned.
I had one (sold now), I was running 10psi like youself, with pod and full 3" exhaust.
No front mount though
Before tune, 1st run, it was 154 rwkws.
After, it was 177 rwkws.
So about $300 for the SAFC and i paid $150 for an hour dyno tune at Unigroup.
I ended up selling the SAFC and installed it on a mates car.
He got it tuned too and got 176 rwkws. Definatley worth looking into and easily saleable when you wanna upgrade.
I now have a Power FC but am putting of the install until i get the front mount done.
Hopefully get around the 190 mark if i also increase to 12psi. Hmmmm, yummy
Hey i have an r33 gtst, with the following mods; Kakimoto cat back exhaust, intercooler, CES double dumps and front pipe, Hi-flowed cat, 500hp fuel pump, blitz pod, heavy duty clutch and running 10psi. With these few mods my car makes 193.7rwkw's in shootout mode 04. The fellas at Apc are the ones who do most of the work on my car, and recomend gettin a dyno run/tune just to adjust timing and boost and obviously to check air/fuel ratios are good. So a dyno tune/run can be a good thing, even though u are limited by the stock computer.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
