Could some one help?
I was driving in Sydney in my Skyline R33 when I was at the lights with a WRX. We both gave it until my Skyline R33 pushing 9lb just over 5000rpm started to get a jerking feeling as the harder I accelerated it didn’t want to go any further. It felt as if I was loosing power after 5000rpm.
Has anyone had this problem, my vehicle is standard just a boost controller set at 9lb.
thanks
Chris
SYDNEY
Hi
I had the same problem with mine, I bought Splitfire coils and solved the prob.
It's just cause your coils are weak and you have boosted your car..
