Hey guys,
i own a Series 1 R33 GTS-T, and plan to remove the rear wing. i want to replace it later down the track with a 'drift' style lip. but for the moment is wondering if there are any 'plugs' to fill the empty holes.
ive herd of them before but have never really seen any.
any idea where to get them? im in sydney also... or any other ideas to fill the holes?
cheers.
https://www.sau.com.au/forums/topic/51496-plugs-r33-remove-rear-wing/
