Hey all,
I own a R33 and have recently fitted my front mount, now whenever i boost the car up past 10 pound and i get the revs up to around 4500 i get a series of backfires comming from the muffler, it feels like i'm hitting rev limmiter and i loose power. I have kind of narrowed it down to these following things.
1 my computer. I'm not sure if it is only registering 7 pound when i am running 10 and only putting enough fuel thru the car the accomodate this.
2 My air fuel sensor might be stuffed up. If it is i have no idea how to get it fixed or what i should be doing with it.
If anybody has had the same problem with their car cause i have heard this is kinda common can u please let me know what you did to fix it and how much it costs.
I will be getting the car dyno tuned soon so hopefully that might also be able to work out the problem.
Thanks
Adam
https://www.sau.com.au/forums/topic/51599-need-advice/
Hey, What front mount did u get put on, and how are you running 10 pound of boost, eg; electronic boost conroller, or bleed tee etc. Also did u fit the intercooler yourself, or did u have a work shop do it for you. It could be hitting your boost cut, or it could be spiking to like 16psi or somthin, also i had a similar problem when i had a Hybrid front mount kit put on my car running high boost, it would break down between 5,000 - 6,000 rpm. Also if u did get a shop to do it they should have road tested it before they gave it back to you. And also maybe you should have your car tunned before increasing boost, as it is good insurance.
https://www.sau.com.au/forums/topic/51599-need-advice/#findComment-1021107
The break down your feeling is your spark plugs, You need to take them out and re-gap the size down to .7
The reason why its doing this is because under load (boost) the spark is trying to jump the gap (1.2 i think plugs are standard) but isn't getting full spark across so you need to lower the gap.
The fuel should be fine at the moment on 10psi, but dont raise the boost any more other wise you will start to lean it out and cause pistons to melt.
have fun,
:D
https://www.sau.com.au/forums/topic/51599-need-advice/#findComment-1021244
    • I also built one, for a bit of a laugh. Pretty happy with it. Basically, obtained a clear garnish, painted it sanded back the paint off the letters, clear coated it. Inserted a 3cm EL strip through a slot I created in one end and sealed it up.
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
