hi all
cranking but not starting...
injectors dont seem to be making any noise and there doesnt seem to be any spark....
does the ignitor control the injectors and ignitors or just the ignitors?
the engine is in a VL commodore - i guess basically the same as a r31 wiring wise...
im using the rb20det computer and wiring...
https://www.sau.com.au/forums/topic/51614-rb20det-no-spark-no-injector-noises/
Check the CAS that it's operating correctly. It should be sending a signal to the ECU so that the ECU knows when to open the injector and fire the coil.
Do you have power for the injectors and the coils?
What do you mean:
i guess i would have power?
? Who installed it all, and wired it up?
Power comes from the battery, via a relay (the ECU switches this power to activate the inj / coil). Test it with a multimeter.
