I'm looking for a suitable intercooler for my R32.
I want around 200rwkws when all my mods are finished.
One shop recommended a 600wx250h tube and fin i/c to use with the std piping.
How effective are intercoolers with top and bottom tanks and inlet and outlet on the same side compared with the regular crossflow type of a similar size?
Does the inlet tank need a divider to take half the charge to the far side of the i/c?
What power can be made before the stock i/c piping becomes restrictive?
https://www.sau.com.au/forums/topic/51643-r32-vertical-flow-intercooler/
i bought one for mine that i don't need to use cause i need to sell it. it is 600x300x80mm thick, very good core with the tanks on the top and bottem. the buy i bought it off had it on a R32 and had just over 200 rwkw's. he said that the cooler is makes the car feel more responsive than stock so they can't be that back.. i'm getting a new end tank because one was cracked. so if you are interested pm me.
They flow well provided they are built using a good design of end tank. In fact can flow better as the distance the air needs to travel to get through the core is shorter, yet cooling capacity isn't harmed as it still cools across the whole length of the core. Really 6 of one, half a dozen of another tho.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
