I have programable ECU and wanted peoples opinion on the best idle ignition timing to use, it's currently 14°.
I have idle probs sometimes but I have big injectors, light flywheel, big turbo and exh cam timing retarded that don't help. I have also played with fuel (dropped) to improve city cycle fuel econ. so I can easily increase it up again to get rid of problem but I want to be more smart about it.
Apart from trying it, will an increase in timing from 14° improve idle quality and reduce stalling etc?
https://www.sau.com.au/forums/topic/51659-idle-ignition-timing-s1-rb25det/
I'm running a Wolf 3D on a Stagea RB25DET, standard injectorsa, but light flywheel. At idle (around 800), its got about 16 deg, but at the rev point below idle its got 19. Apparently produces more torque to pull the engine out of a stall.
I thought the timing for an RB25DET was 15 deg. I'm pretty sure thats what the Nissan sticker says under my bonnet. i have a very smooth idle... it has been set to 740rpm... according to my rsm it is never more then +-10rpm!!!
I reckon you are on the right track, as I have backed by base timing of a little and it caused a slightly lower and rougher idle
I adjusted this using the idle control valve on the plenum, but I reckon a small increase in timing (say around 1 to 2 degrees) should make it better rather than worse
Nothing to do with ignition timing. All it does is change the amount of air bleeding into the plenum at idle (closed throttle).
Thanks guys.
Actuall I should clarify, idle quality is OK, it just stalls under certain conditions with the current fueling I have.
I had a go on the way home from work....plenty of bloody idling opportunities!... and increased from 14° prgressively to 16°. Was funny though, woudl still stall sometimes but other time with all parameters the same it would be OK. The ECU has other idle functionality I need to play with so I'll keep ya posted.
Edit: Just read in book that 15-32° is typical for motors, so I'll jack it right up and see how it goes.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
