Hi Mate et al,
I sort of know the position you are in and can only concur with what the others are saying. I had a bit to spend on my first car back in the day (not as much, and due to family misfortune) and ended up taking advice from a family friend (who owns a prominant advanced driving school in Sydney) and ended up investing in a little 1.8 Audi A3. Then spent the first few years I was driving doing numerous driving courses at the various schools and quickly discovered that even my little 1.8 had limits well beyond those of my own.
I took a fair while before I was confident that I could "graduate" up to something abit more powerful.
Anyway, by the sound of it you have a good attitude and are sensible. So my suggestion is to get a small (read "light") manual NA car, you'll find that you will be able to have heaps of fun and will have a platform that doesn't have too steep a learning curve. Then take your time and aim to slowly and steadily improve yourself, it's better to take your time becoming a great driver than quickly becoming an ex-driver. Even Michael Shumacher didn't become Michael Shumacher over night.  :P
Also, with your budget you should be able to get something pretty pimpin for picking up the ladies.
Cheers,
Jae
PS: if you look to your Dad that you're making a wise decision now, he'll probably soften up to other suggestions down the track.
OT: I recognise your avatar ;) enjoying your new GTR? I took you for the test drive.
  • Replies 41
Teamshadow: Mate get your dad to buy you the new Mx-5.
- Rear Wheel Drive
- Turbo
- Convertible
- Insanely fun even at slow speeds
- 50/50 weight distribution
- The ladies will dig you
And its a very respectable, sensible sports car.
Either that or the new mini. (for the same reasons above)..
Just cars that will teach you how to drive, be as fun as having a ferret in your undies, but at the same time not be over powerful.
Once you've driven that for a few years, learnt how to drive.. upgrade to a turbo r34 skyline :P
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
