i got a garrett T3/T04b custom turbo, brand new it is oil and water cooled roller bearing the info for the turbo is T3 To4b . The compressor wheel is a 54 trim and the compressor housing is a 60ar . The turbine side is a 48ar with a standard T3 flange. this is pretty much a bolt on for a skyline rb2*det engines and also a VLT or anything with a T3 flange that has oil and water cooling, only problem is that the exhuast flange going to the dump pipe is different tho most exhuast can be modifyed for very cheap i am asking $950ono for the turbo if u would like pic's or more info please email me at [email protected]
Thanks
Is it internally or externally wastegated, what sought of power is it good for and ya got any pics
it is internal wastegate and give me ur email address and i will send u pic's when i brought it i was told by the people who built it that it should do 450-500hp
Thanks
.48 a/r turbine housing will need 20+psi to make more power than stock, will be still a struggle at that without an external gate. This turbo would be more suited to a CA. May be an easy option to bolt on your standard Turbine housing or even a VG30. will have a tonne more power at less boost and also bolt straight on.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
