Has anyone here seen any of there own multinova pictures before? I am wondering how clear they are? And how can they actually prove it's you? I got sent a fine which i don't think it was me driving (the police seem to) and want to contest it.
They can enhance the image for you so you can see who was driving - make an appointment and go and view it. If everyone did this the system coouldnt handle it anyway so you should always ask to see the photo even if you know it was you. This will create a backlog in the photo section :wassup:
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1022346
they dont use the pic if they cant tell which car it was.
I went a few months ago to chek one of mine
The pics wernt clear at all when it comes to seeing the driver of the vehicle
i went there to chek out mine, if its a month old dont bother they will tell u to get lost.
there arrogent ****'s as well - think ther gods gift to this world.
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1022708
My GF got a fine about a year ago, didn't think it was her as it was @10.30am on a Tuesday morning in Guildford and we both worked in Ossie Park at the time. So she went in to check it out (and your right they are arogant f*#ks) the pic was a Nissan Pathfinder and she owns a Pulsar......... The guy goes "There you go Lady plan as day" GF replied "Bloody right it's as plain as day I own a Pulsar." The number plates were different by one number hers is a 5 and the Pathfinder 6, they don't cross reference the plate to the vehicle. So go and check it out.
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1022783
r33impul, i had something similar happen to me.
except i got a fine for driving some landcruiser which was owned by the water corporation, i went in there to view the photo and the guy goes 'there you go, its you'. i had a small argument with the guy and he finally got me a pen and paper and i had to write a few sentences saying i have never driven that car before blah blah..
i wonder how many people actually just pay fines without checking on them?
letemlaf: hasnt the law changed now so that whomever own's the car is responsible for whom was driving it at the time? you can't just say you have no idea who was driving it anymore or was this still to come into effect?
Shaun
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1022898
i saw my pic and it was plain as day, me.... :(
letemlaf: as far as i know, its your responisbility to find out who was driving your car the time of the infringement.....basically if they prove its your car (number plates) you get the fine unless you can prove it was someone else by them signing the form....etc. :D
so, if you were wearing a helmet or a mask or something i would think that you would still get the fine.
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1023131
I went through one getting out the way of a speeding cop car.
Went down to check out the photo and explain what happened. Guess what,
no cop car on the whole roll of film to back up my story....
The lesson is if they are in a hurry, too bad. Move over in your own time.
Same goes for red light cameras. They will do you no matter what, so let
the ambulance crash the curb to get around.
Also, if two or more cars can be seen within the photo frame markers then
the camera will fuse the readout and you won't get done.
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1024023
does that mean you only get the fine and not the loss of points?
i know that if u own a business that is owned by another business which is overseas etc it becomes too hard to track. same with taxes
https://www.sau.com.au/forums/topic/51715-multinova-photos/#findComment-1024388
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
