You registered your username on the first day of school holidays, then your first post was inflammatory.
Around school holiday times there tend to be a lots of posts like that.
** Umm what BU5TER said **
Just seeing if there were any skylines that did any good at jaboree...Or were all the owners to busy on their computers, posting about how quick there cars are going to be.
Well I said I'd run 12.6 and ran 12.4 so I can't have been that busy...
