  • Replies 80
The ones you just made (pic above this post) are the best lids i've seen.
Looking very aggressive >:) Good job!
Can you post some more photos of that one? With more light if possible and looking staright on instead of looking down.
If you were to sell these, how much?
Cheers~!
Cheers~!
thanx for the compliment, as soon as i get up in the morning i'll post a few more pics.
im quite happy with these eyelids, but i will have about 4 different types for people to choose from.
i knew these latest ones would be the most popular so i cut 5 pairs at work today in case i stuffed a pair or whatever.
the pair in the photo where made from 0.6mm colourbond metal (rustproof i think) sprayed with etch primer rustproof paint, 2 coats, then 3 coats of primer putty to get out any discrepencies, lightly sanded then 3 coats of gloss black followed by one smooth coat of clear laquer, looks professional i reckon.
only problem is i temporarily fastened it with double sided tape so i could post the pictures.
in the morning i'll fasten them down with silicon, that way they'll be secure, but if i decide to remove them one day the silicon will be easy enough to remove with a scraper or just by pealing it off without any damage to the headlight.
i will be selling these eyelids, probably prepared with everything i mentioned above excluding the paint and the laquer, that way all you'll have to do is spray them according to the colour of your car, and gluing them down in whatever way you want...
havent come up with a price as yet, i'll get back to you on that.
thanx for all your input guys, really appreciated.
if you have any other ideas on designs for eyelids for the r33 series 1 let me know ([email protected]) or if you want eyelids for any other car let me know, only problem is i'll need at least the outline of the top of the headlight, if you know what i mean. the way i designed these eyelids was trial and error (cut 1, run to the car, check it, alter it, ran back to the computer, redesigned it, cut it, tried again) or if theres anything you need laser cut also let me know, i have a post in the sau classifieds on laser cut jobs, go there for more info...
well, i think im happy with the final product of the last set of eyelids i posted.
i will be putting these in the sau classifieds for $30 a pair, sprayed with 2 coats of etch primer for rust prevention, followed by 3 coats of primer putty, so all you have to do is spray them the colour you want, and glue them on.
thanx again for all your replies and opinions, it helped alot.
i dont know but how will any1 ever know that your parkers arent meant to be in the front bar and the indicators where your parkers are??
i did it because i thought the orange indicators in the front bar look crappy. plus i wanted some decent spotlights, now i do
laser cut the brackets for them too... laser sure comes in handy
  • 3 weeks later...
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
