hi looking at upgrading my exhaust manifold and wanting some advise form people who have. ive upgraded the turbo to a 500ps unit and it sits on the standard mani with a custom twin dump/front pipe. So if anyone can tell me were to get a good manifold that locates back to the stock turbo position would be great. also the gains they have got from doing it . what is the most hp a stock manifold on a rb25 can support?
cheers guys
cheers guys
Hi i can have made for you a custom exhaust manifold in stainless steal,but its expensive.i all so can supply plenium kits and inlets for rb20,25,30.contact me at
[email protected].I can send pics of all item.good kw gains
cheers steve k
I have one of those china manifolds and they look good dunno if it makes more power but,I guess I'll find out soon :wassup:
Here's some pics of mine
China power 1
China power 2
China power 3
China power 4
I have got one like r31 power's to slap on my rb25 but i have to say it doesn't really look like any sort of improvment maybe even more restrictive then the stock log. It wouldn't really suprise me if people with these things are loosing power....but they look pritty from above. :headspin:
Live and learn i guess but i would be going for something custom next time round or a jap one and not a cheap pre-fab thing.
John
r31 power;
cool let me know how it goes. might be ok because i think there trying to replica a hks. someone was telling me they have problems with them leeking and cracking when getting real hot. thanks for the pics. Did you order it from the site, how long did it take and what was the total cost after shipping?
cheers.
The reports I'm getting about these chinese manifolds via anecdotes is that work better than you'd expect and they are stronger than what you've heard about SS manifolds.
Some grinding is needed to get them to fit but nothing a competant shop can't work out.
T.
Have you ever noticed that these spaghetti leg fabed manifiolds (the locally made ones) look like a nest of snakes ? I have to wonder if the contorted angles that some of the tubes use when they reach the collector are much good . Some US designs merge the primaries into a single tube which then feeds the turbo , the WRC engines seem to do this too . At least then the primaries are facing the desired direction and not wasting gas velocily and heat energy trying to oxy the collector off . On a six cylinder engine I recon the split pulse (123,456) would be easier to produce (than spaghetti special) and give better response and less reversion , also access to the turbo is better .
HKS do cast iron manifolds for RB20/25/26 (single turbo) which are along these lines and usually have provision for an external waste gate . If you can find one of these it would have the advantage of cast iron (less chance of cracking/warping) a guaranteed fit and the opportunity to use a higher performance waste gate system later if you need to . Also if you can do this part for reasonable money it has the potential to open a lot doors to future upgrades . Its no problem to make a cover plate for the external gate mount if you need to use an integral one for cost or cop reasons . You'll stand a better chance of convincing Joe average Wood Duck that its factory rather than the scaffold and ****y poo custom job .
Just my two paseos worth , cheers A .
T.
This is good news for me... i was starting to think i'd wasted my money. :D
Now this grinding? where? is there much of it to be done. i have just got my head back and have not test fit it yet.
Also discopotato yes i know there are some horrible aussie custom ones floating around and like you said aussie ones tend to favour the long runner equal length design. I think i saw a few threads on the short runner jap manifolds vs aussie ones on here and performance forums ages ago.
John
ive got one those chinese manifolds, power has gone from 212rwkws at 17.5psi to 224 rwkws at 17.5psi, you be the judge.
Carl,
People also report a much nicer sound and more throttle response. Do you get this?
I love a car that leaps off the line and goes from 60-80-100 in a jump.
T.
Its good to hear people are getting good results from these.
I haven't even got my one on the head yet so i have no practical knowage of how they work in the real world yet.
Its just I was a little bit dissapointed in the clean-up & weld quality inside the runners on my one but if it works. :cooldance:
I will have my engine back together in a week or two so i'll let you guys know how it goes.
John
PS thats a nice markup they are putting on those at autobarn. :uhh:
Has anyone thought about an R31 GTSR original or better copy? To look at they are a damn sight prettier, and normally of it looks right then it works right.
My 2c is no matter which manifold you get, wrap it up in it jammies:) Mine is ceramic coated and it works ok but under bonnet temps still go through the roof, so when i get the car back ill be giving it a once over with high temp exhaust wrap. That and brace the turbo up off the head so that the thin walled 800deg C exhaust isnt relied upon to support the weight of the turbo
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
