In my 1)extreme boredom and 2)extremely lame attmept to get everyone to talk more, I have created this thread. The idea, obviously, is to post quotes, preferably car related but its not compulsory. Ones of a humerous nature would be much better than ones that come with realistic goal in mind :(...A fine example of this could be degrading the riced and rediculous.
https://www.sau.com.au/forums/topic/51764-quotes/
hehe had similar quote thing at work but they write it on whiteboard in lunch/kitchen room instead..
some quotes I can still remember:
"remind me not to heat up my salad in the microwave"
"I want to goto japan and see the snow monkeys"
dilbert quote:
"shut up and reboot, shut up and hang up."
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1022870
With strength comes limits.
Today, I will be running 4 bar.
I have 11,500rpm and I intend on using every last one of them.
What? The speedo only goes to 320?
Lights for beginners: Red = Stop. Green = Go. Amber = Go faster. Blue = Warp factor 10.
Objects in mirror no longer matter.
If in doubt, increase boost.
Engineered to be feared.
Insert smartass comment here.
If you start to see in B&W then you know your pulling enough G's.
Don't panic as you will black out soon.
I only use the brakes so I can accelerate all over again.
Please fasten your seatbelts and stow all your valuables prior to take off.
Drive it like you stole it.
Trust me, I got an E in physics!
Wastegates are for sissies.
When I grow up, I wanna be a mad scientist!
I am kept in place by G-forces, not seatbelts.
Revs, they're the #1 replacement for displacement
Do you have any idea how fast you were going ? Sorry Officer the speedo only goes to 320
You mean there is life outside of Internet? You're shittin' me!
I haven't seen daylight in six months.
Living in a cave with 47 computers and an Internet feed, located near a Dominoes pizza. See !d.
Living alone, get out once a week to buy food, no more than once a month to do laundry. All surfaces covered.
Will drift for food
If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports?
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1024335
    • After you start it by holding the throttle wide open, does it then idle correctly without throttle or does it stall? If not it sounds like one of the injectors might be stuck partly open. You could also drain your oil and check for a heap of fuel in it. If it doesn't idle there is something wrong with the tune (unlikely, because it worked when it was tuned), or something changed on your car like the AAC or cold start valve no longer working correctly. BTW, I know we are a multi-cultural forum now, but "gas" makes no sense as a term for the pedal that opens a petrol engine's throttle, either directly or electronically.
    • I bought the NZEFI 1000CC injectors with the ballaster resistor delete pack. It started fine for a few days and even drove it to the Tuners dyno and back. Then one day i drove it to work, and on my way out of the office, the car wouldn't start. Unless i put the gas pedal all the way to the floor and then crank the engine over.  Called the tuner and we tried a bunch of different settings but trying to figure it out now. Anyone else experience this? Haltech Platninum Pro. https://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
    • After the windscreen motor from r31 skyline or pintara, located Grafton NSW
    • I'd do it all again in a heart beat. Well, not all, I'd make some different choices in which mods. But I'd definitely still spend all the money.
    • Hey y'all, Looking local to USA, for just side skirts and rear bumper or half bumper. Pics for reference below: Top is east bear style rear bumper, bottom is uras style rear half bumper. Side skirts are interchangeable.  Thanks y'all!
