In my 1)extreme boredom and 2)extremely lame attmept to get everyone to talk more, I have created this thread. The idea, obviously, is to post quotes, preferably car related but its not compulsory. Ones of a humerous nature would be much better than ones that come with realistic goal in mind :(...A fine example of this could be degrading the riced and rediculous.
https://www.sau.com.au/forums/topic/51764-quotes/
hehe had similar quote thing at work but they write it on whiteboard in lunch/kitchen room instead..
some quotes I can still remember:
"remind me not to heat up my salad in the microwave"
"I want to goto japan and see the snow monkeys"
dilbert quote:
"shut up and reboot, shut up and hang up."
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1022870
With strength comes limits.
Today, I will be running 4 bar.
I have 11,500rpm and I intend on using every last one of them.
What? The speedo only goes to 320?
Lights for beginners: Red = Stop. Green = Go. Amber = Go faster. Blue = Warp factor 10.
Objects in mirror no longer matter.
If in doubt, increase boost.
Engineered to be feared.
Insert smartass comment here.
If you start to see in B&W then you know your pulling enough G's.
Don't panic as you will black out soon.
I only use the brakes so I can accelerate all over again.
Please fasten your seatbelts and stow all your valuables prior to take off.
Drive it like you stole it.
Trust me, I got an E in physics!
Wastegates are for sissies.
When I grow up, I wanna be a mad scientist!
I am kept in place by G-forces, not seatbelts.
Revs, they're the #1 replacement for displacement
Do you have any idea how fast you were going ? Sorry Officer the speedo only goes to 320
You mean there is life outside of Internet? You're shittin' me!
I haven't seen daylight in six months.
Living in a cave with 47 computers and an Internet feed, located near a Dominoes pizza. See !d.
Living alone, get out once a week to buy food, no more than once a month to do laundry. All surfaces covered.
Will drift for food
If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports?
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1024335
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
