Ok,
The club is up and running, the sun is out and shinning, so it's time to go on another big cruise. (About time!) :wassup:
The cruise will be on Saturday October 16, and we'll be heading up to Warburton. We still have to map the cruise out so once that has been done I will update this post with the final details.
But you can be sure in the tradition of our previous cruises we'll find you some fantastic roads to have some fun on.
Cruise Details
Meeting Place and Time.
Western End of the Upper Ferntree Gully Train Station Car Park.
Burwood Hwy.
Melways Reference: Map 74 F6.
10:30am with an expected departure time of 11:00am.
This cruise is fairly long - extremely twisty in places - and the road has some sections that are VERY narrow. Consequently we will be running it at a controlled safe speed. But this is probably one of the best scenery cruises we will do through Australia's tallest forest so we'll be asking everyone to back off, relax and enjoy the drive.
Please make sure that you have a FULL tank of fuel when you start. There is both Optimax and Ultimate available less that 500m from our starting point. The next available 98RON fuel will be an optimax that is about 180kms from the start of the cruise - and that is through very twisty conditions. Total distance of the cruise (back to Ferntree Gully) is about 250kms. Depending on how long we stop for lunch I expect to be back well before 5pm.
Members
All the members that come along - be sure to bring along your membership cards as we have the club stickers to hand out. They look fantastic.
If there are guys out there that haven't joined the club and wish too - we will have membership forms available on the day. Most of the cruises for next year will be for members only.
https://www.sau.com.au/forums/topic/51780-offical-cruise-161004-warburton/
  • Replies 120
Of coarse there will be - we will be stopping for lunch at Marysville. We "may" have a nice property to use as a lunch stop - otherwise we'll be sitting down at the river in Warburton. If you've never been there before its a really awesome little town.
My wife loves it there! :(
No abcent - this cruise will be open to everyone. Members only cruises will start in the new year. This will be a chance for those guys sitting on the fence on whether they want to sign up or not to come and check the club out. So if they like it they can sign up at the cruise.
:D
Guest
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
