car was fine on monday, running great as always and i had booked it in for its 100,000k service with SST.
come tuesday i am driving back from work (after finding that some idiot had put chewing gum on my windows) only to notice the battery and HICAS lights flicker on and off a couple of times. a few minutes later my car felt and sounded like it was running rough (missing a cylinder).
drove to work the next day and again it was fine but again driving home it did the same as before only this time when idling the car revved itself a few times then cut out, again flashing the HICAS and battery and oil lights.
doing the same thing today except it didn't run fine this morning. checked the oil and everything last night and i can't figure out what the problem is, though i am no qualified mechanic.
hopefully SST can sort it next week. until then... any ideas ?? anyone had this happen ??
:D
https://www.sau.com.au/forums/topic/51811-weird-engine-trouble/
man that one beats me, dont know y all those lights would be flashing, have u got or know neone with another NA, i would borrow there ecu and plug it in and see if it solves ur problems.... definately electrical.
took it in to SST's new workshop for it's service etc, tuneup was great for the first half hour of driving but alas didn't solve the problem :D now it's burning oil with blue smoke pouring out of the exhaust and it's gotten even worse since the service.
it's going back into SST tomorrow so ant can check the detenation sensors and computer etc though i think it might have been a fuelling issue. hopefully it gets sorted and when i do find out what it was i'll be sure to fill you in. :)
hey. sorry to hijack this threa. I got some sort of weird engine trouble as well. me and my mate took my na line out for a right royal thrashin, and now when the whole car shakes with vibrations. Feels like a bolt has come loose holdin the engine together. Anyone had this problem b4???
that was my first thought too :P but SST have changed all the plugs.
so far SST have swapped parts in and out and ruled out everything apart from the ECU and the airflow metre...
plus it is over fueling at low revs, which is odd seeing as i have never adjusted the fueling.
*sigh*
  • 1 month later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
