car was fine on monday, running great as always and i had booked it in for its 100,000k service with SST.
come tuesday i am driving back from work (after finding that some idiot had put chewing gum on my windows) only to notice the battery and HICAS lights flicker on and off a couple of times. a few minutes later my car felt and sounded like it was running rough (missing a cylinder).
drove to work the next day and again it was fine but again driving home it did the same as before only this time when idling the car revved itself a few times then cut out, again flashing the HICAS and battery and oil lights.
doing the same thing today except it didn't run fine this morning. checked the oil and everything last night and i can't figure out what the problem is, though i am no qualified mechanic.
hopefully SST can sort it next week. until then... any ideas ?? anyone had this happen ??
:D
https://www.sau.com.au/forums/topic/51811-weird-engine-trouble/
man that one beats me, dont know y all those lights would be flashing, have u got or know neone with another NA, i would borrow there ecu and plug it in and see if it solves ur problems.... definately electrical.
took it in to SST's new workshop for it's service etc, tuneup was great for the first half hour of driving but alas didn't solve the problem :D now it's burning oil with blue smoke pouring out of the exhaust and it's gotten even worse since the service.
it's going back into SST tomorrow so ant can check the detenation sensors and computer etc though i think it might have been a fuelling issue. hopefully it gets sorted and when i do find out what it was i'll be sure to fill you in. :)
hey. sorry to hijack this threa. I got some sort of weird engine trouble as well. me and my mate took my na line out for a right royal thrashin, and now when the whole car shakes with vibrations. Feels like a bolt has come loose holdin the engine together. Anyone had this problem b4???
that was my first thought too :P but SST have changed all the plugs.
so far SST have swapped parts in and out and ruled out everything apart from the ECU and the airflow metre...
plus it is over fueling at low revs, which is odd seeing as i have never adjusted the fueling.
*sigh*
  • 1 month later...
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
