What do you reckon freight would be worth?
It's to the point know that Im either gonna use 1 from an RB25 or I'm waiting on pics to see if I can use the 2 from an RB26. I'd prefer the 2, but if I don't see these pics, I'll take you up on your offer
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
