Yeah -- Know about practicality...............Pity you live so far away from me, you could do mine next time, I can't get even close to that 1/2 hour.   Jeeeeszuss, that would be worth watching.
30 mins for R33, never done an 32 before. Imagine it couldn't be too much different.
Would u believe that there are guys in these forums that actually do it way quicker than that!!!
5uck!! like to see how many scratches they put on their car!!! :wassup:
Yeah, if you lived closer, be a pleasure!!, and we'd take our time about it too!
I've since confirmed that my Platinums should still get close to 100000km's on a turbo car, with few mods....ace!!
I am running boch 4's and had a bit of a miss when on the gas.
Just upgradded to splitfire coils and the miss is less by a long shot but is still there.
WIll probs get som BCPR6EIX-11 plugs and I'll let you all know how it goes.
Are boch 4's more of wank feature or r they resonable?
RedDrifter - i wonder if there was a problem with spark plugs and no need to go to splitfires in the first place.
Yeah I am thinking the same but its a bit late now to worry about it.
Well I guess my ignition system is alot stronger now.
I have 6 in it now, had it since i bought it but recently i found out nissan recommends 5 for the series 1 r32 and 6 for the rest.
i think that could be reason for not starting up properly when cold as few guys had a very similar problem with colder spark plug.
i might ger some coppers to see how it goes with different heat range.
I just installed iridium BKR7EIx11 last night. This is with the standard 1.1mm gap which maybe ok with low boosted cars but not high boosted cars. Now, i have a slight miss in the midrange when my boost is wound upto 20psi. Reading thru the net, high boosted cars require a smaller gap, hence the turbo blowing the flame out with a large gap. Now also reading you can gap iridium just be careful with that iridium tip. Make sure you dont hurt it with the feeler guage.
So im going to pull them out tonight and gap them down to .95 or 1.0.
hey robbo almost right. you don't need a smaller gap to run more boost, what you really need is a stronger spark, eg better coils or a new ignition system :) Gapping the plugs down to .8 or similar is the easy solution but you will probably lose power
Ive got Spitfires coils allready. I reckon 1.0mm gap will be perfect.
There's no "better" or "worse" in heat ranges. The heat range the manufacturer says is worked out by the combustion dynamics of the standard engine. Generally speaking the closer the insulation comes to the end of the centre electrode the cooler the plug. That is because the amount of metal protruding without being in contact with material which can dissipate the heat is less. A couple of simple examples as to why heat ranges may be changed with advantage would be in,say, a worn engine, burning some oil and running on lower compression, may tend to oil up plugs and misfire. A hotter plug would burn off the oil and not misfire. An engine with ,say, greater boost or compression,may tend to 'pre-ignite' fuel producing 'running - on' or 'knocking', because the centre electrode glows red hot and ignites the fuel prematutely. A cooler plug would fix it. Whilst that is unlikely with modern Engine Management systems, the measures to fix it [mods to fuel,mixture,timing,etc] damp down performance. Prob the only real way with a Modified engine, is a supply of different plugs and a dyno THERE"S A HAPPY THOUGHT.
  • 2 months later...
BK type plugs (ISO) are too short, you need BCP plugs. BK plugs are ISO standard which is shorter than the Japanese standard BCP type plugs.
:spcartman
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
