1) What voltage should out from 1st pin on MAF sensor (RB20DET red top, screw on MAF sensor is for changing injector's timing)
can somebody read a voltage from 1st pin? i have currently 0.9V, a range is between 0v..6v, which should i set for optimal fuel/air mixture?
2) how to adjust a TPS on this engine?
https://www.sau.com.au/forums/topic/51906-rb20det-red-top-a-few-questions/
