Hey I know this is probably a really ooooold question, but has anyone in Perth tried to change their timing belt by themselves? Does anyone know where I can get a CAS 'O' ring and a CAS gasket for a 94 R33 GTST Skyline? Doesn't have to be in Perth. Or does anyone know of somewhere that isn't going to charge me big bucks to get it changed?
"Oh yeah, well if he's so smart, how come he's dead?"
https://www.sau.com.au/forums/topic/51909-timing-belt-time/
You most certainly can do it yourself, but unless you know what your doing, then it's not worth the risk.
You should be able to get the parts from any of the Nissan outlets, if your a SAUWA member we get trade price at DVG Morley who sell Nissan parts, ring and speak to Scott.
https://www.sau.com.au/forums/topic/51909-timing-belt-time/#findComment-1024898
I did mine at home and took around three hours, ended up putting the timing belt on just one tooth out on the exhaust side and the car was running like shit, so just be carful to match up the correct marks.
I also heard that the crank pulleys have to be tightend correctly or it will fall out? True or False anyone know?
https://www.sau.com.au/forums/topic/51909-timing-belt-time/#findComment-1026334
Good value, thanks for the help guys! I reckon I'll give it a go it doesn't sound too hard as long as I take my time. MacGuyver can do it!
"If it's clear and yellow, you've got juice there fellow. If it's tangy and brown you're in cider town!"
https://www.sau.com.au/forums/topic/51909-timing-belt-time/#findComment-1034002
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
