Ive been wanting a R33 OR R34 GTR for some time since I sold the gts25t.
Then came across the RX7 series 8. Has anyone compared the 2 cars. Not fussed about fuel economy, more so the difference in power delivery, driving pleasure and handling.
Im aware the gtr is more powerful, but in the real world is it actually faster?
Anyone had any first hand experience with problems with the rotary engine?
Im really undecided any help appreciated.
Cheers
Oz. :D
https://www.sau.com.au/forums/topic/51950-rx-7-series-8-vs-gtr/
Drive them both first. Personally i'd prefer the RX7, they are said to be absolutely addictive. Plus it'd be a more practical daily driver(more luxuries etc) and would be just as quick as a GTR in everything except 1/4 mile sprints(and how often do you do that anyway?).
Depends on the level of modifications..
I believe the S8 has the oil problems sorted with the TT setup by then.
If you're looking at limited modifications, they're both going to be very reliable.
I've had a big hp 13BT before and they're definately a good thing, just need to look after it very closely. Im still a nissan man tho, which is why I still drive a GTR :D
If you are serious about your track performance, I'd go the RX7
BlackRobin: Don't feed the trolls... it is school holidays, just ignore him.
I would go the R34, simply for the extra interior room. The FD is tiny inside.
My head touches the roof and I am not that tall!
I could never drive it with a helmet and that means no track days which means arrrrghhh!
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
