ARghhh :) I want a clutch that will allow me a better ride in peak hour. Currently have a Nismo Twin Plate clutch, and I'm sick of stalling the freaking thing in peak hour (how embarrassing :x )
I'm used to my Toyota Liteace with it's lose clutch, I couldn't stall it if I tried. This Nismo Twin Plate has a "sweet spot" about the size of a pin head :twisted: It's either a delayed take off, a schreech n jerk, or a stall. Not to mention the bunny hopping it likes to do in first.
I might be completely wrong in thinking it's my clutch causing the bunny hopping action, but I just want something that makes me look a fool in peak hour, with less trffic at night and early mornings it's all fine because you can get a nice launch from the lights without the worry of all three lanes infront blocked and a bus infront of you :roll:
Any ideas ? I think I'll need to go cruising with you guys who are a little more technical so I can try and work out whats wrong (prolly just whats between the seat and the steering wheel eh !)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1240
so jimbo how does it go the car I remember drooling like most of the people on geoffs list over that one. I'd give it a few more weeksb4 changing casue anything else won't handel the power roumour has it that the nismo twin plate is alot easier.
cheers
meggala
any 0-100 times or 1/4 mile times
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1245
It's going as expected. The car is just as I had hoped for, unfortunately I think the driver leaves a lot to be desired :oops: but hopfully this will come with practice. It's not everyday you go from driving a Liteace to a Skyline 8)
At the moment she's looking rather stocky due to taking a lot of things off for the third Tier inspection. However I will be putting everything back over the ext two weeks, and hopefully getting engineers certificates for the most common things that the cops will try and defect me for, just to make my life a little easier.
I thinik I'll leave the clutch, just because I'm prolly copping out blaming the hardware for my failure to understand how to use it together to get the take off I'm after in differing conditions. HopefullyI can get some pointers off you veterans :)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1246
Prank,
Check out the 6 puk clutch that UAS sells. I've help install one in a GT4 and one in a R32 GTS4.
Both have a really light pedal but have good clamping preasure (about 40% more than standard.
They bite quickish, but very drivable in traffic.
I think they are $595 exchange for the GTS-t's.
J
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1256
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
