Hi people.....This week i will have finished a set of front upper arms......These will give you a variable camber adjustment.....i would like to see who would be interested in such a thing.....i havent worked out a fixed price yet although theres quite a bit of work in these so i wont be giving them away......If theres enough interest i will do the sums and let you guys know.....there will be a percentage that will be donated to SAU for all sales made........ but those that will be interested should know the going cost on these ...not to mention the importance of trying to save those expensive tyres on track days!
Thanks
https://www.sau.com.au/forums/topic/52018-camber-arms-for-r33r34/
after pricing up what it will cost to make the arms properly i dont think its viable to make them on a large scale and sell them ....theres just not enought interest not to mention theres most likely an offset bush thats available to give you more camber but none adjustable....i will still be making them...but most likely just for my own use...profile cutting,pipe bending,bush's,powder coating,plus the materials,my fabrication time and a donation to the club brings the cost to $450 a pair....something i think people will not pay
ok guys...heres how we make things.....First we make a jig for the item.....This ensures all our parts fit and are exactly the same......we make a shaft up for all the mounting points then eitheir drill a hole and bolt the material to the jig during the manufacturing process or make it a nice slide on slide off fit.....where the bush's fit on the arms i have machined down a peice of pipe the exact bush and on the bolt end i got a peice of solid bar and drilled a 12mm bolt hole through it(this is the size of the bolt on the outer side)As you can see we have all our mounting points covered.......As you can see we then remove the bolt then product can then be swung away and lifted off the jig........This jig has been made double sided.....the rear of the jig is used for left arms and the front is used for right.....It always pay to have a bit of a think before starting to make the jig :( we then fabricate the product around this jig.....i will post the units being made if people are interested
