I have an issue with my Power FC showing a knock on gear changes. Normally there is no problem with detonation, the most it will display is maybe 10 on the graph. However when you go for the next gear there is a spike on the display, sufficient sometimes to make the warning light flash.
If anyone could help with the following:
Is this normal?
Is this anything to worry about?
Are there settings other than the 20x20 maps that can be adjusted?
Should I be looking at the BOV's (Apparently not standard, but plumbed back. In my defence I didn't change them, it came like that)
Setup is on an RB26DETT with 13lb boost, exhaust & not much more.
Any help would be appreciated
https://www.sau.com.au/forums/topic/52053-power-fc-knock-issue/
Is this normal?
The knock level warning is adjustable, have a look at the Commander when the dash warning flashes. That will tell you how big the problem is. If the warning is set at 30 and it goes to 31 then don't worry, if it goes to 90 then I would be looking for a reason. You should also note that the dash warning light comes on for other reasons than knock. The Commander readings will tell you what it is.
We get dash warning flash due to the rpm limiter (ignition cut) and, as meshmesh suggested, when the twin plate clutch rattles.
Hope that helps
Thanks for that fellas.
Unfortunately I dont have a twin plate clutch, but I do have some lovely fluffy dice.
It is not the engine buzzing to the red line as the light sometimes comes on when you back off as well as when you change gears. I'm fairly sure I wasn't pulling 8 grand in fifth....
I will check the thresh hold for the knock sensor, but am pretty confident it will be whatever Apexi set it up for at the factory, which I think is about sixty.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
