They have HICAS.
SEWID WHATS THE EASIEST WAY OF CHECKING IF ITS ALL WORKING OK, THE REASON I ASK HAD A SET OF SPRINGS PUT IN AND THEN TAKEN OUT ?(WAS WAY TOO LOW) MY MATE NOTICED WHEN I WAS REVERSING THE BACK WHEELS WERE NOT TURNING? I DIDNT THINK THEY TURNED?
