Trust filters are definitely a non oiled filter element..... i dont know of any shops in Melbourne but Advan Performance in Sydney stock these filters and could get you the replacement element without any problems.....
must be because they have a thing against AFM's. "Self cleaning" my ass..
are you saying AFMs self cleaning? thats only on the earlier model AFMs as i dont see any self cleaning wire on the 4 pin types (r32,r33). its only for cleaning dust and not the oil residue crap left by oil based pods
You can use degreaser [aerated kero] and then wash out with a hose in water.  Blow dry or air dry for a day or so, and 'viola, ze air filter she ez clean'.  Do it all the time, they are made to be reused.  Then you buy a priority brand air filter element oil and spray or tip approx. two tablespoons of oil onto the clean and dry filter and work it through the whole element.  You should have nil excess.  The oil is important, it traps the fine dust particles that the foam cannot filter out.  Best hint is to clean the element regularly [<5000km].  If you have oil leaving the filter, you have used too much.  The oil has to be throughout the filter, but not able to be squeezed out at all.
These same principle filters are used everywhere [motorcycles, dozers, scrapers, trucks, 4wd, and cars].  They are a good product and work extremely well however they are open to abuse and neglect.  They do take some learning skills for the novice.  They breath freely, filter very well, and give years of fault free low cost service.  They DO NOT impede performance [they actually have superior breathing capability to many std filters].
Another reason for the filter being oiled is as a fire retardant for backfires etc, a non oiled filter will catch alight and burn [especially if there is fuel spitting back through the carby].  This reason is probably not so relevant for turbo vehicles, but is essential for motorcycles [i saw a m/c burn almost to the ground with a backfire and airfilter incident out on the roadside, no fire extinguisher, no water].
I run a HKS pod in the skyline, a foam Unifilter in the Hilux, a foam K&N in the TBS motorcycle, and a custom foam filter in my other TSS m/c [both road bikes], and they are all serviced and oiled as above with nil probs.
Thanx for the advice/talking to!!
I certainly wish u had been at the Autobearn store, over hearing my conversation with the staff member, and u interjected with this advice. (would have saved me both money and grief!!!
Ta, Mark.
No probs, glad to be able to give something back to the forum [on a topic I am conversant with]. Usually I am whinging and asking for help, so its a small change to be on the other side.
Remember, don't use just any oil, it must be a faom air filter oil. And don't use any foam, the foam on your filter is an open cell and probably a dual or triple layer one - in each successive layer the open cell size is smaller. Therefore big dirt gets trapped on the outside, medium dirt in the middle, and fine dust is stopped by the last layer.
Just make sure your filter is meant to be oiled [not all filters are engineered to be oiled, but the majority of foam filters are]. Get on the www and check out the manufacturers site for details.
Thanx TT150v!!
Mark
  • 3 years later...
hello boys and girls. im in the process of cleaning my air filter at the moment. and its just drying now. im not sure if i should oil it or not? its a blizt suspower LM coretype. i have no idea if i should or shouldnt oil it. i did last time and it caught heapssss of shit witch i guess is a good thing but yeah... unsure :) any helps is apprichiated! (wasnt good at english :()
hello boys and girls. im in the process of cleaning my air filter at the moment. and its just drying now. im not sure if i should oil it or not? its a blizt suspower LM coretype. i have no idea if i should or shouldnt oil it. i did last time and it caught heapssss of shit witch i guess is a good thing but yeah... unsure :) any helps is apprichiated! (wasnt good at english :rolleyes:)
They are DRY element like the TRUST ones, jpas usually dont use oiled elements as they know how much AFM's hate the stuff.
The Replacement blitz cores are cheap and can usually be got overnight if you get stuck.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
