i fit car windscreens for ajob u can repair cracks depends on there size and how old they are of course the sooner u get it done the better because no dirt has gotten inside it u should be able to get a cheaper windscree then that but im from the gold coast so it will vary in prices i guess if u are there make sure u watch them most windscreen fitters when they cut the windscren out scratch the paint under the windscreen even though i cant be seen when the windscreen is in guarentee it will rust and 2 years down the track u have to pay again to get the screen out and get the rust fixed becasue your screen is leaking s if u are there have a really close look around the black uerathane on the body ad any scrachers just paint like an edge primer over it so it wont rust hope that helps i cann help u with prices since u live in melb sorry
https://www.sau.com.au/forums/topic/52093-need-windscreen/#findComment-1028255
