hey all
this may sound like a bit of a stupid question but i have gotten an r32 not long ago now and when purchasing it already had an aftermarket cd player installed (Pioneer). Now there is no aerial on the vehicle and when trying to listen to radio the headunit does not pick up any stations. Now i am wondering if this is due to the way the headunit has been wired up? Can you not get any radio reception in the r32's? Or what could it be?
Any help appreciated, just been giving my cds a good work out and wouldnt mind some radio.
thanx
Jason
https://www.sau.com.au/forums/topic/52105-r32-radio/
On the R32 the antennae are the fine wires in the front and rear windscreen.
Is your Pioneer deck an aussie or jap model? The jap models only pick up a few aussie stations as the bandwidths overlap a bit.
If it's a jap deck you could have a bandwidth shifter fitted.
If it's an aussie model then it may not have been fitted correctly. I think there is an antenna booster in the boot of some if not all R32s. I've been told the black and red wire, that is taped to the antenna coax that plugs into the back of the deck, needs to be wired to the power antenna (blue) wire that comes out of the deck so the booster can get 12 volts.
When the factory deck is replaced with an aftermarket deck you need an adapter plug.
The factory plug has 2 pins and the a/m deck only uses the pin from the rear windscreen.
One suitable adapter on the market is Aerpro AP348A.
I hope that helps.
https://www.sau.com.au/forums/topic/52105-r32-radio/#findComment-1028155
Hey Jaystar,
I have also just picked up an R32 with an after market radio and had the exact same problem as you, no radio reception. After pulling the deck and checking it turned out that the previous installed had not connect the cores of the cars antenna cable to the core of the adapter plug. 10mins and solder iron fixed that problem. Just be careful as the core wires are really thin and can break real easy if your heavy handed.
Hope that helps.
https://www.sau.com.au/forums/topic/52105-r32-radio/#findComment-1029562
I had the same issue and was due to it being a jap spec radio. Fitted the band expander and all sorted. 2 weeks later i just bought a new headunit.
ok guys i found the black and red wire which has a little plastic connector on it.
Do i remove it from this connector and add a metal male connector on the end of it so i can plug it into the blue and white wire coming off of the headunit?
is this all i have to do? or do i have to do something with the 2 pin connector also?
it looks like an aerial one but doesnt fit on the headunit.
i made an error the current headunit in it is a jvc kd-sx695.
all help appreciated
thanx
Jason
https://www.sau.com.au/forums/topic/52105-r32-radio/#findComment-1034878
ok i have fitted the adaptor so that i can plug the aerial into back of headunit and radio is working fine. Because my aerial is the little wire built into the windscreen do i still need to hook up this red and black wire to the blue one out of the head unit?
because it says auto aerial or something like that?
if so can someone explain why to me please.
thanx
jason
https://www.sau.com.au/forums/topic/52105-r32-radio/#findComment-1043626
yes you do. that wire runs a small antenna amplifier. if you switch to AM you will notice that it doesnt work. FM around the city will be fine but outside of it FM will be patchy.
connecting it up ( blue wire on most radio) to the ant control will solve this problem.
https://www.sau.com.au/forums/topic/52105-r32-radio/#findComment-1043677
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
