Painting Calipers
Mick
 Share
Well i was all set to paint my calipers but i just couldnt bring my self to do it, i mean i just dont wana do the quick cover job on them, when i goto do something i always make sure i do it right the first time, a little example is once i got pissed off with the wires hanging down too far in my kingswood so instead of just stickin my hands under there and using a few cable ties i ended up stripping the whole interior and i ripped the entire wiring loom out of the whole car and i made a new loom from scratch for the whole car and i bound it with this rubber tape that bonds to itself so its like the loom is rubber coated and i made the loom that neat that every plug was in an inch of what it was suposed to be connected to, and i even drew up a complete wiring schematic ...... took quite a while, but the end job was worth it ..
Anyways gettin back on topic, Is there a way i can take the calipers off without having to bleed them when i put them back on ?
cos i wana spray the whole caliper and not just the bits showing .. the reason i dont wana have to bleed them is because im at home by myself, so it would be impossibe to get them operational by myself ..... I was thinking, what if i left the lines connected and just unbolted the caliper and stuck a peice of wood in betweenas i slide it off .. that way i should be able to spray the whole caliper.. and i also wana spray the disc hub as well, so if i could do it this way is it easy to get the disc off ?
the fronts look like they will just slip off once the caliper is removed but the back looks like it may be a little involved cos of the handbrake cable ..
Any help or thougts on this would be apreciated ...
dude, you will probably be able to get the front off, we did on my mums commo before we changed the brake pads, but I guess you will have to make sure they dont close on you, otherwise you will be getting the crow bar out to force them apart :D
Sumo
Dude, sorry I can't answer your q directly, as I have absolutely no idea. However I was just thinking if you are worried about bleeding the brakes by yourself, I thought that it was possible to get a valve for bleeding your brakes that is non return, so you can do 'em by yourself:) Just thought it might be a bit easier than dicking around. Please post up your results, with any tips for people attempting this as I am planning on having a go at the calipers myself pretty soon.
Cheers
Steve
Really, really nice job there. How did you prep them? What sort of paints did you use and how did you finish them? I have been thinking about doing the same, but haven't tried anything like that before so any tips would be great
As for the valve, I beleive they are available from most auto shops. I just remebered a way that a mate said he did it too, although it was a long time back so I'm not sure if I have it exactly straight (and he was a bit of a bush mechanic). He said it was possible by running a thin plastic tube of the bleed into a plastic container as it pumped out the air and if it sucked back it only got fluid. Sounds about right to me - 'spose you could always experiment on a mates first:p
Steve
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
