I had a failure on number 5 big end (not alot of fun) ,so i strip down the engine to then find that my bores are 87mm and are badly scored! they will clean up at 88mm (wich will reduce the block strengh and limit horse power) but then the next problem is that i need to find a good set of forged pistons that retain the 8.5:1 commpression ratio. I since then have found out the ARIAS piston do not go out to 88mm. WISCO made a 88mm but reduce the commpression and are of unkown quailty. Can any recconmend what i can do?? thanks :freak:
https://www.sau.com.au/forums/topic/52111-rb-26-forged-pistons/
ive used wiseco in quite a few of my race bike, seeyagtr, im surprised wiseco wont custom build a set for you, and yes i realise owning a GTR sends u broke, i think its merli who summed it up quite well, GTR=Money Pit
I only hear good things about Wiseco, particularly from guys with race bikes as well as race engine builders such as JHH Engineering?! Anyone have other comments on these pistons??
I ran wiseco's in my GTS-t and they handled it just fine. The guy who bought it off me flogged the hell out of it and did a big end as well, piston's where like the day I bought them. same story basically they are a reputable brand with a good product. it's all the same grade aluminium in the end!
was just about to say resleeve bottom end sice only one cylinder should b fine with the heat side of things and strength.tomei and acl pistons do 88 and are the shit also with compresion they can shave head or thin head gasket to keep compression up.
Thanks for all the info!! It would be sweet to get hold of a secondhand block, even out to 87mm ( good bore )would be sweet but my efforts in tying to get hold of one have proved fruitless! To use 88mm pistons and then to shave the block/head would be the go. I also had bad scoring on 2 and 4 bores that might clean up at 87.5 but i am still left with a floged out number 5!!!! I have not ket priced up a full resleve. I can get the JE Forged Pistons for $1600 custom made wich i did not think was too bad,
I have to weight up the best way to go
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
