has anyone done this is it an easy job???
can I just remove the bolts, slide out old gasket and slide in new one or will the whole turbo have to be removed. or will I risk bits falling into turbo?? Car is sounding like shit and can see a large part of that gasket missing so need to replace it.
anyone got any info, also where to buy gaskets for I spose its a t3 flange, has a hks 2510 turbo but spose its the same flange as its bolts onto factory manifold.
https://www.sau.com.au/forums/topic/52112-replaceing-turbo-manifold-gasket/
