  • Replies 49
Well... it was pretty much as i suspected.
Found out the radiator is a larger aftermarket unit...
ECU is a standard R33 GTR ECU...
Sam took me for a drive (Dr_Drift) in it... well... now i know what it can do in the right hands hahaha when we got back i was a little shakey and in need of some new underpants but soon got over it :(
We finally got to put it on the Dyno and had a couple of runs... second one blowing a nice little flame but was restricted by the mixture reader in the exhaust pipe... so... we took it out ;)
and this happened :)
http://www.skylinesaustralia.com/photopost.../414flameon.wmv - right click save as ;) its not the greatest quality but i cant actually get the video off the camera and on to the HDD so it will have to do.
Now down to the numbers :(
The car made 207rwkw on 9PSI :)
472nm torque.
Not bad figures for a stock GTR engine.... in a 1350kg cefiro ;)
so what happened to the guy from NS.com who was gonna put a deposit?
still for sale?
well he came down and loved it once we went for a drive...
but havent heard from him sense... i think i might have to start charging for rides... this thing isnt exactly easy on the fuel pocket :(
and yes... its still for sale.
ok i wanna get a car i can drive on the road without having my kidneys rearranged and at the moment im waiting on too many people selling cars... so the first offer over 16k can take it.
if this helps anyone...
it doesnt seem as tho it is going to be as hard as i originally thought to comply it... but i still dont have the money to do it.
so to get it on the rd will be 3-4k...
so if anyone wants it... im willing to take any offers from 16k.... nothing less
  • 4 weeks later...
mate if i complied it and had it on the road it either wouldnt be for sale OR it would be for sale for over 20k.
i dont know how much u think it costs to comply and register a car but it aint 1 grand. This isnt a charity sale
its all good. But this can stay for sale for 3 years the price isnt going to drop 3 grand :)
like i said... im in no hurry.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
