Who intrested in a DYNO day
Count me in too. Have we decided on which workshop it'll be at? I can do most saturdays, and can certainly make arrangments if I know far enough in advance, but in general, saturdays are good.
Haven't had a dyno done since the week I bought my car, and it was bone stock when I got it - should be a different story now!
So yep - I'm in, & any Saturday is good for me.
Simon.
  • Replies 51
Guest nismogtsx
Price like i said is by the hour... so its $88 per hour....
$44 should be enough for each of you... As i said in a previous post bring about $60... Just in case... It should only take about 30 minutes for each car... So be on the ball and dont hog the dyno... Simple... Then at the end we can just split the bill....
What's wrong "nismogtsx"?
Why have you dissapeared all of a sudden?
Was it because someone was apparently using your e-mail the whole time on this forum and you didnt knwo about it?
I'm sure Danny from Team Drift king Motorsport would love to see you at the dyno day....
Maybe you could spin some more of your bullsh*t stories down there.....
