Hey guys and girls.
I just had a 650hp Walbro Pump fitted to my R34GT-T
Problem.
After changing gear, there is a slight surge-backoff-surge feel, only on light throttle applications.
Also, my fuel economy went to the sh1tehouse. Half a tank, 100klms.
What is the problem?
Is the return line too small to handle all that fuel and it's pumping it all through the engine and out the exhaust pipe?
Is my pump sus?
What is the surge?
Is this all related?
IS the earth going to swap magnetic polar ends soon and is this the only warning we are going to get?
So many questions.
BASS OUT
https://www.sau.com.au/forums/topic/52175-just-installed-a-new-pump-problems/
  • Replies 44
But shouldn't the Standard regulator just dump what it doesn't need, ie extra pressure or flow to the return line?
Plently of people here are running big pumps with standard regs.....
SK
I was waiting with baited breath for your response.
What would be the standard pressure in the rail at idle?
What would be the standard pressure in the rail on load? I don't have a dyno, how would I check this???
Fuel Filter..... So for instance if the fuel filter is blocked, this would do what compared to a clean one?
SK
Oh I feel so humble, baited breath was it? :cuddle:
Standard pressure is 36-38 psi at idle, you don't need a dyno to check that, just a fuel pressure gauge. Pressure whilst under load (has boost) can be checked by jacking the car up and running it against the brake (hand and foot) for a quick burst. The fuel pressure should stay the same at 36-38 psi above boost. So if you get 10 psi boost, the gauge should read 46-48 psi. Don't do it for too long though, the brakes and water temp don't like it.
Fuel filter is just a check, I have heard of so many Skylines lately with old, unchanged, dirty fuel filters causing bad running. They are such a cheap item, often overlooked for more exotic hardware, that can hurt you.
Hope that helps
Standard reg. and a Bosch 044 is no problem.
You need to get it dyno tuned.
I have an 044 + Apexi/Nismo reg. and I dyno'ed it a day after I had the pump put in. Fuel consumption is normal.
T.
Hi Tony, I have replaced a number of fuel pumps with both larger and smaller capacity pumps and not had to tune the car. If there are no pre existing issues or problems, the tune should not change one little bit.
See this I don't get...
Big pump therefore more flow.
But the reg. should still provide the 'cork' to stop the flow.
So I'm guessing the performance aspect of a big pump and no other mods is that the increased flow makes the motor get more fuel, more quickly so the car feels more 'surgey', more responsive?
When the new pump went into my car it did feel more surgey, like more kick, response off the line.
But that could be just a flawed impression.
T.
T.
Hi Tony, the fuel pressure regulator is not really a "cork to stop flow" its more like a flood gate that opens to bypass the flow.
Okay, just had a pressure gauge on the line.
Car primes to about 50psi, then when it starts it stay up at 50psi for about 15 seconds.
Then it drops back to abuot 35psi.
Then when driving around, the pressure rises as it should with boost.
My mechanic says that they have a two stage pressure function. Seems to make sence as when I change gear and the car starts to spool (mind you, I'm hardly on the throttle at all) the guage drops back a few psi and then flicks up again to about 45psi.
Is this normal?
Could my pneumatic boost control be playing havoc with the fuel pressure?
BASS OUT
Is this normal?
BASS OUT
Sounds normal to me Bass, when you change gear the boost escapes via the BOV. This removes boost pressure from the fuel pressure regulator and it drops the fuel pressure in the fuel rail accordingly.
I have no idea what this means though...
"Two stage" I wonder what he means by that, the fuel pressure varies with boost so it has "multiple stages". The fuel pump has 2 voltage levels, maybe that's what he means.
:cooldance
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
