  • Replies 44
yep,
Two voltages
That shouldn't change the fuel rail pressure, it only affects the flow from the pump. I thinks it is more of a noise reduction effort than anything else, so you can't hear the pump when sitting idling. :idea:
Question.
Should the pressure rise when the pump changes voltages?
BASS OUT
No not usually, even on low voltage they have enough to pump 36-38 psi, after all the engine isn't using very much at idle. :burnout:
This was something I found odd when I installed my GTR pump. The car was rich as buggery and I was running almost full static advance to make any power (Really).
I changed the filter to no avail, but it was full of crap anyway so this was a good move.
I then installed the Malpassi and drove to get the PFC installed and tuned and all was better. Strange but true. I have no explanation.
See it all the time, the standard pump was stuffed and the filter blocked. So when it was tuned, the tuner compensated for the low fuel pressure. Then when you put the big pump in and a new filter, the correct amount of pressure was being applied at the rail and the engine runs rich. This is where the BS stories start about retuning being needed after larger fuel pumps are installed.
Bottom line, if it had 38 psi rail pressure (above boost) when it was tuned then it will run the same as long as it has 38 psi (above boost) rail pressure. You could put 50 pumps on it, as long as the rail pressure was 38 psi it would still run the same A/F ratios.
Hope that clarifies :D
yep,
Two voltages
Yeah, I've heard of this before in 180s as well. It appears that the engine management only applies the full voltage at higher revs by limiting the ground at lower revs. You can get a constant full voltage applied if you wire the pump directly to the chassis for a "complete" earth (i.e 0V at all revs, as opposed to 1-2V at low revs, and 0V only in the upper rev range).
you sure about the ground thing? in the mazda's the fuel pump voltage gets cut instead. so when hit boost you get 12v so you get full pressure, and then it drops to 10v for idling and cruising.
a trick was to bypass the whole thing and run a fat cable directly from the battery through a relay which would give the pump 14.4v, which would increase the pressure a bit more over stock.
i have seen stock fuel ppumps die running at 14.4v constantly (happened to my stock laser pump), dont know about aftermarket fuel pumps.
steve
Hope that clarifies :)
I'd agree whole heartedly if it had ever been tuned, but on the stock computer....
The only thing you have prompted me to think of is that the stock pump was buggered, so why did it then run so rich that I had to crank in so much advance? I'm still puzzled by this one. (Queue X files music)
Put the standard pump & old filter back in and measure the fuel rail pressure. SK is on to something here.
I have an upgraded Bosche pump, standard fuel rail, standard fuel pressure regulator, 550cc injectors and 330rwkw - PLUS 300+ kms per tank.
I'm certain there would ba a logical explanation, but I changed the filter, no difference, then installed the malpassi and pfc and had the tune. Anyways it runs fine now.
So do you measure your duty cycle on the injectors? I was set to upgrade mine before the next step up.
steve
The pressure regulator controls the pressure...not the pump...the only way it will alter is if the reg is totally overcome by the supply and cant let off enough volume
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
