Mind if I ask S/K about fuel consumption of 230klm per 50 litres (and that's with a very light right foot) around town but on the highway I get an even 10 klm per litre (various speeds). Would this signify toooooooo rich at around town speeds or am I barking up the wrong tree?
(Power FC + Apexi boost control kit+Apexi Pod filter+Z32 AFM+ 3" turbo back system+FMIC)
Or is someone helping them selves to my fuel?
Just joking about the last part
Cheers
Muz
https://www.sau.com.au/forums/topic/52199-lousy-fuel-consumption/
Sure is terrible and yep had two tunes done (same bloke - that could be the problem) and produces good HP (210rwkw at 1 bar) but I have it set at only .7 bar most times. Our best local tuner is not PFC literate and those tunes were done at another location.
Cheers
Muz
That doesn't sound too good re: fuel consumption.
Plus shouldn't an r34 be making more than 210rwkw with those mods at 14psi? (sure it might be the dyno, but to me that seems to be 10-20+ odd rwkw off the norm?)
I know it's bad to start saying check this and check that when you don't really have a clue (I'm still new to this thing), but have you had the timing checked? Maybe try a different tuner..
wil..
Thanks wiich,
Ahh no, an R34 GTT in standard form will only put out about 206 kw at the flywheel. That equates to somewhere around the 140-150 mark at the wheels (I'm open to correction from those that will know the correct equation) so 210 is not too shabby under those circs. The problem that I have is reasoning why I get excellent mileage on the highway and really disasterous figures around town.
Go to another tuner you say. Not all that easy when you live 2000klms from the capital city and there are no decent PFC tuners in between. We have to work with what we have unfortunately.
Cheers
Muz
How does your boost come on?
Is it tuned for an aggressive boost ramp?
Maybe if the boost is like a light switch, you are boosting more than you should around town, and when you get on the freeway you aren't boosting, therefore not using much fuel......
How many Litre per 100kms Muz?
I use 13 L/100km on the highway and 15-18 around town normally but have been known to hit 33!
I am also concerned about fuel consumption but I only have a modified stock ECU. I think there must be something in the tune.
Hi Bass Junky,
No, I have a very progressive boost setup and rarely get on boost around town. (can't afford the points after my travels thru NSW).
ABO BOB, Good to hear from you mate. How is the 4 door going, any more trips down to Wakefield? Consumption on the highway is an even 10 or better and around town up above 20. I also think it has to be in the tune but when I look at all the numbers in PFC H/C they mean squat to me. Looks like I will have to invest in a data logit set-up.
yeah, i know mine is running pretty rich as well, gets lots of burps and pops from the zorst ...
pfc is on route from jap (well, when they are in stock) will be interesting to see if it makes a difference
cheers
i get about the same as tang0 maby the s2 mods are more economical but i know my car is running rich
running 0.9 bar
Hi Bass Junky,
Highway is very good Muz. Around town there must be something in the tune rather than anything broken. I get 13.6ish on the highway.
I've been to the creek once since I last saw you but I've now had my racing wheels and tyres stolen from my garage so no more racing for a while.
i struggle to get 300kms to 55L driving to work and back (all 60kph zones)
as soon as i hit the highway its awsome, 600kms to 55L when i drove down to grafton.
It must be the closed loop kickin in, i have a standard ecu with a tuneable chip. makes about 200rwhp in a r32 sedan.
Geez A/B,
Sorry to hear about the wheels mate and yes I'm beginning to think that it is all in the tune. Checked the system out this morning on the way to work (via H/C) and all voltages appear to be where they should be so it has to be in the numbers. Oh for a decent PFC tuner up here. Getting to the point where I'm thinking about flying a tuner up from Brisbane just so he can coach our local tuner in the finer points of a PFC. PM'd the other reply to ya.
Mick, I would be happy with anything over 300 around town.
Cheers
Muz
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
