Charcters on JDM plates?????????
Could someone please tell me what the character on the left of the numbers on Japanese rego plates mean?
I understand that the characters at the top of the plate denote the prefecture, I am simply curious what the single one means.
Thanks
ps. I put it here cause i figured you people living in Japan would know best......i apologise if this is not the appropriate place for this thread.
https://www.sau.com.au/forums/topic/52231-charcters-on-jdm-plates/
So it has no reference to vehicle type/mass etc?
Means nothing then?
that's the top numbers your refering to
- 500 (used to be 5x): depending on engine capacity, car weight and width which I don't know exactly but don't really care. As an example: most small sedans/hatches, coupes like integra, silvia, celica, roadster MR2/S, roadsters etc...early skylines, chasers, evos, sti, rx-7 I believe are in this class too.
- 300 (used to be 3x): same as above but larger, heavier class...NSX, Supra, GTO, GT-R, RX-7, Evo, Z32/33, RX-8, Chasers, Skylines, Stageas etc
- Yellow plates: kei plates... I don't take note of the numbers.
- 400: lorries, special vehicles
- 800 (used tobe 88): marked police cars and emergency services ambos, fire brigade
from what i heard here's how it goes, 2.1 liter engine and below is 500 plates, 2.2 and above is 300 plates, bus and trucks are 100. my wifes prelude is a 300 plate because its a 2.2 liter engine. thats the reason why r32 gts-t's and gts-4 has a 500 plate (and thats how u can tell if people just slapped in a gtr badge hehe).
the letter beside it doesnt really mean anything, except for us which is Y or E or A, which denotes (supposedly) tax free (but we still pay for it though, because the base commander "insist"). :bs!:
Yukio, as I said any of 3 main criterias I mentioned and also a few other things.
My Evo and a s14 are both 2.0L and have 300 plates...s13 and S15 are 500 plates...but it's no big deal. As you said only makes it easier to spot posers...but then I have seen RB26DETT in HNR32 with 500 plates.
Good that you mentioned it, I forgot about the 100 plates.
Also plates with a red diagonal line across the plates are dealer plates.
i think so too, but coz us here on US base we have different coding just to make it less complicated, they made it simple, yellow plates and motorcycles pay 3,000 yen, 500 plates pay 5,000 yen or some small number like that then 300 plates pay 19,990 yen then 300 plates with 4.5 liter engine and up pays 47,000 something yen for a year.
I thought the numbers, which denote tax code (right?) are also determined by the weight of the vehicle?
From what I have observed I think 300 plates are starting from 2.0L up capacity, 1200kg+ weight and 1700mm+ width.
Because the early Evos and WRX meets all of the above except for width and they are 500 plates...or the old 7x plates.
Justin I don't think the 1 has any significance, more they ran out of possible plates and just tag the additional digit to it....
I think the basic numbers, 1, 3, 5 etc are used and then each prefecture can add numbers after that dependening on needs...
so a 55 code is the same as a 500 code since they both start with a 5.
Over here in Yamanashi I've seen 55 / 500 / 501 / 33 / 300 / etc
One question - what the deal with a Kei car that has a black plate with yellow writing...not a yellow plate with black writing. Seen a couple about but could never figure it out.
Aaaah, I could be mistaken, but I remember someone saying the black plate with yellow writing is registered as a commercial vehicle...
as for the 5xx etc numbers - I asked that question at the dealership - was told that only the number of digits and the first digit are important - and that you could, in fact, choose the other digits if you liked
it was a 50:50 japanese/english conversation - it sounded a bit weird to me, so not sure if something was lost in translation
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
