This is not my car but I do know it and know that it's a true "wolf in sheep's clothing". I also know that it's a clean and VERY fast car !!! Anyway, here's the lowdown :)
Silver 1996 R33 Skyline GT-R Vspec
Built to look stock standard from the outside, but every aspect of the car has been designed to handle the 800 HP+ performance every day with total reliability.
Engine:
- Huge bar & plate intercooler + plumbing.
- 2 x GFB blow-off valves.
- Super-strong bottom end inc. crank, rods, forged pistons, Nismo bearings, rod bolts.
- Nismo oil & water pumps.
- 2 x Garret 450HP ball-bearing turbos.
- HKS gaskets used throughout + HKS S/S head gasket.
- Tomei cams and vernier cam gears.
- Hand ported, flowbenched head with O/S sodium filled valves and mirror polished ports.
- Extrusion honed exhaust and intake manifolds.
- Everything match-ported.
- All heat-loaded parts HPC coated.
- All load-bearing parts cryogenically treated.
- Oil/air separator.
- Cusco catch can
- Braided lines.
- Dual 3" S/Steel exhaust from turbos to tips.
- Large oil-cooler w/ braided lines.
- Trust/GReddy sump baffles.
- Computer: Apexi Power-FC PRO with 3-bar MAP sensors and hand controller.
- Boost Control: Apexi AVC-R.
- All machining, balancing and assembly to blueprint or better specifications.
- Professionally assembled and tuned.
- On the dyno made 402kw at approx. 6000rpm, then produced wheelspin after that. Conservative power estimate: 820 flywheel HP
Fuel System:
- Sard 740cc injectors.
- Sard rising rate fuel press. regulator.
- Custom fuel rail with press. equalisation.
- Nismo in-tank primary fuel pump.
- Bosch Motorsport external Fuel pump.
- Custom swirl-pot.
- All fittings, lines, pumps and swirl-pot hidden.
Drivetrain:
- OS Giken twin-plate clutch.
- 35 degree straight-cut gear-set.
- Larger diameter shafts all round.
- Nismo synchro set.
- All parts cryogenically treated.
- Strengthened and tightened diffs.
- 10-plate wet clutch upgrade for 4WD system.
- Stronger driveshafts and CV joints.
Other:
- Nismo suspension all round.
- Massive Porche GT-3RS brakes w/competition pads.
- Nolathane bushings.
- Camber & castor modifications.
- Flaken AZENIS 255/40 tyres.
- Nismo 320kph instrument cluster.
- Nismo center-stack gauges.
- Nismo short-shifter.
- Power-FC hand controller.
- G-Reddy exhaust temp gauge.
- Apexi AVC-R controller.
- Fully automated turbo timer.
- 4-stage programmable shift light.
- Momo steering wheel w/ HICAS compatible boss kit.
- Pioneer stereo w/ 2 amps, splits all round and Pioneer sub.
Rego to Jan 05
Price: $75,000 or near offer.
NO TIME WASTERS PLEASE AND A SECURITY DEPOSIT WILL BE REQUIRED BEFORE TEST DRIVE ALLOWED !!
Contact: Mick on 0410-558-711
https://www.sau.com.au/forums/topic/52242-96-r33-gt-r-v-spec-modified/
Sad but true pete ! I just don't want to be around when the sale takes place. I hate seeing a grown man cry......god knows, I couldn't sell it if I owned it. Prol sell a kidney first !!!
  • 3 weeks later...
- On the dyno made 402kw at approx. 6000rpm, then produced wheelspin after that. Conservative power estimate: 820 flywheel HP( your ad)
can you just tell me something how did you come to the conclusion it makes 800flywheel horsepower when i make 450awkwand i was told i only make about 650 fly wheel horsepower. and i didnt get wheelspin
If your pulling 450 kw @ all 4 wheels thats around 600hp @ all 4 wheels so you would be pushing a bit more then 650 hp at the flywheel at a very rough guess you would be some where around the 750-800 hp mark unless you were on a very happy dyno
hehe "happy dyno"!
450kw equals 603hp.....conversion is something like 1.34. So i'd say more than 650hp at the fly for you wreckedhead.
Impressive power either way...for both cars
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
