How makes the better adjustable cam wheels for a '98 SII Gts2.5t?
I only want an exhaust cam at this point [or so I have been advised].
I know they are about $200, and HKS, Tomei, OS Giken etc etc make them, but is there any difference in applicacation?
https://www.sau.com.au/forums/topic/52243-adjustable-cam-wheels/
im goin for HKS but alot of ppl told me the Tomei ones are best...
i also heard that some ppl change only the exhaust side in gts-t's and not the inlet side...would like to have some comments on this too if anyone knows...
cheers...ben.
I have had HKS items, and I would say from my experience steer clear. They wore down in no time. I think they're made from aluminium or something, thats why they wear faster. I believe Tomei items are stainless steel and so last heaps longer.
If someone would like to correct me here these please do. I'd rather know the truth than talk outta my arse, but my HKS experience wasn't a good one (WASTE of MONEY) and what I know I got from my engine builder.
Hi guys, HKS pulleys are made from hardened alloy and seem to be the lightest, I haven't weighed all brands though. I have seen 1 pair of worn HKS pulleys and the cambelt was so tight you could play it like a violin. I have seen many pairs not showing any wear, but the cambelts were tensioned correctly. I have never seen a stainless steel camshaft pulley. They would weigh so much it would be like having 3 flywheels anyway.
I use the Jun adj pulleys, they utilise the standard Nissan outer with a billet alloy inner to give the adjustment. So the durability is the same as the standard pulleys with regard to teeth. They are very boring to look at, but I always run covers so you can't see them anyway.
If someone wants to send me one of every type of pulley, we have a rockwell tester so I can confirm the teeth hardness of each brand. It's not a destruction test, you will get them back able to be used. If someone who had a problem with the HKS pulleys had done a proper hardness test and found them to be deficient I am sure they would have gotten more than their money back.
Hope that makes sense :uh-huh:
Try the ones from Speed Technology / EFI Hardware in Melbourne. They don't come in pretty anodised colours, and they don't have degree markings on the wheel, but they are a lot cheaper than the "brand names", and they do exactly the same job.
cheers...ben.
Its to do with the VVT [variable valve timing], if you install a cam wheel on the inlet side, you loose the VVT. The loss then outweighs the benefit. Thanks to SK for this advice.
My debt to SK increases by the hour...........................[i'll end up having to sell my body to science just to get enough money to pay him].
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
