Hey there guys and girls. I was just reading that you guys are lucky enough to have a new International Motorsport Facility about to be built in Bunbury. Looks like they will be hosting a round of the Formula Nipon in April possibly followed by a round of the JGTC in December 2005! Looks like I'll be packing my bags and heading on over, most likey followed by half of SAU Vic :D
More info can be found at
www.bunbury.wa.gov.au
or at
www.pimm.org
there is a download of the proposal here -
http://www.bunbury.wa.gov.au/Downloads/BIC...buryLaunch1.pdf
All I can say is.....bastards :)
https://www.sau.com.au/forums/topic/52250-wa-to-host-jgtc-round-in-2005maybe/
  • Replies 63
Havin the JGTC would be like all my Christmases come at once! As Paul said though this would be nice if it evntuates but has been in the pipeline for a long time :-(
This would be an awesome event though for us to attend as a group.. we could have an SAU coporate box!!! ;-)
Yeah it's pretty small in comparison but if you have a look at the .PDF file it has some pictures of the track. It's a LOT smaller that the China track. The China track is a state of the art facility with a lot bigger seating capacity and facilities.
but seeing as the new F1 circuit in China cost $600million, I would imagine the $60million there planning on spending would be a bit low.
Land is a lot more expensive in China because its a rare commodity where here there's a bit mroe of an abundance.
It wont be as big as China's etc ..... but hell its better than nothing!! Finally Perth gets to host a decent event :(
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
