Need a Hi-Flow Cat >> where to get one @ good $??
Flying performance (www.flyn.com.au) are selling 8L High Flow Cats. I think they may even be Catco ones, on Ebay starting bid $199. I got one for $200. It's on the way. Or you can buy straight from their website for about $250.
dont expect the the rwc thing will be cut and dry, my rwc cos me $1200 and took a week to get sorted.
things to look for
tyres, any sign of wear at all
sterring wheel, if not stock
make sure the places acually knows what size rotors your brakes are supposed to have
any body damage that may have taken place during shipage, look underneath the body
robin once u have it complied i know a place where u can get a good RWC from... they dont try and rip u off like everyone else
burkey - dont worry mate.. u will learn to ignore his ranting
lol who cares... shut up denham and let him get a cat :)
dont listen to denham blackrobin... no one else does ;)
what does a radiator air guide do again nark? divert air AWAY from the radiator hey? :)
We all know that blackrobin is gonna go back to the cat that came on the car from japan after the rwc ;)
i didnt say it diverted it away u idiot... i didnt see the point as air was gonna get to it anyway.
anyway... just get a catco.
Back to square 1...
Failed my RWC today + still have no Engineering certificate also... my Registration was booked in for tomorrow. Not going well at the moment.
Driving the car with the standard feels like I got BIG MUMMA LISA is sitting in the back seat and they also chucked on a resinator about the size of 3 melways stacked on top of each other.
Inark.. I will send you a PM for the roadworthy place.... this list was given to me by RWC place to get fixed / looked at.
External wastegate
Drilled rear rotors have hairline cracks (common for drilled rotors yeh?)
Turbo Timer (easy fix)
Horn (because it was stolen by shipping co. - also easy fix)
Battery clamp (original battery went flat and could not hold a charge so bought a new one, smaller - easy fix)
Tank exhaust sheild to close to my milo tin (easy fix)
I pick the good ones don't I...
Thanks for your help and advice so far... I'm starting to hate my car and I've only driven it about 45km TOTAL.
Back to square 1...
External wastegate
I still have a 3' stainless steel cat in my wreck i think, u can have it for cheap. :uzi:
DIY = $80  but still i have to double check if it still there or not. I should.
Find out...
A. 3"
B. If you still got it, condition... pfft... I will probably gut it anyway.
I will DIY if you can let me konw A & B
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
